Compress A Video File For An Email With Different Methods?
Usually files are large than what our emails accounts allow us. o want to send a movie video to one of my friends. How can I compress a video file for email?
Method 1- Using Compression software
Step 1: For the files larger than 4 GB, we need to download a compression program such as 7-Zip, WinRAR, Archiver.
Step 2: Adjust the compression settings accordingly. Select 7-Zip and then Add to archive. There you can change the compression settings.
Step 3: Split a file into multiple smaller files from a large compressed one.
Method 2- Compressing large videos Step 1: Download and launch Avidemux.
Step 2: Load a video file.
Step 3: Set to "Mpeg4 AVC (x264)" from "Video Output" drop-down menu and "Audio Output" to "AAC (Face)" and "Output Format" to "MP4 Mixer".
Step 4: In the Video Output section, click on Configure button.
Step 5: In the General tab, find the Rate Control button.
Step 6: From the drop-down menu, select video size and click on Save.
Notifications
