Computation for shape average cisco
I want to do some calculation relevant to the shape average Cisco suggest me how can i perform computation for shape average Cisco .
Hello Owen,
You have flexibly when Configuring a Cisco router to perform traffic shaping you need to classify packets and apply various traffic shaping policies in different classes.
For implementation traffic shaping for packet output from an interface use this command "Shape [average | peak] mean-rate [[burst-size] [excess-burst-size]]" remember you don't have to set burst-size or excess burst. Window during which BC is sent Class-bases shaping will change its computation for TC depending shaping higher or lower than 320Kbps
BC=8000 bits if rate is <=320Kbps,otherwise shaping rate*Tc
TC=BC/shaping rate if the rate is <=320Kbps, otherwise 25ms
BE=BC always
