Compute simple payroll in Java
I just need to make a simple payroll in Java. Can you forward some good coding templates? I need to connect to a database as well. I know I need to learn a lot but I need the basics first.
Hi Joseph,
I have read your problem. It is very hard in studying C Language specially Java but there are a lot of sites that can help you with it. If you want to make a simple payroll program, then I prefer you to follow this link:
Simple Payroll Program in Java
It is very easy to understand because it explains everything.
If you want to learn basic Java then I do prefer you with this site:
Hope that it really helps you.
Thanks and more power.
