Best Computer & AntiVirus Software
Hi, Rabbi
If you were to ask any computer savvy community about what was the best FREE Antivirus available for download over the web, more often than not they will say that Avast Home Edition 6.0 is the best Free Antivirus software by a long shot.
One of the reasons that makes Avast 6.0 the choice of most users is because with Avast 6.0 the whole process from installing to scanning had been made quick and easy without any loss to its effectiveness in detecting harmful programs.
The best thing about Avast 6.0 is that the program itself doesn’t consume a lot of memory when running; therefore a powerful computer is not a must.
Of course selecting the best Antivirus that can cater to your needs best still comes down to preference and there is a wide range of free antivirus tools that you can select from.
Here are some links for you to check out for you to get a better grasp as to what Antivirus might fit your needs best.
Link 1Â GIZMO'S Best Free Antivirus Software
I’m not sure if there is really a free antivirus that a user can use. It’s the fact that this kind of software helps you protect the integrity and security of your own personal computer and its developer, of course, needs to gain profit from it for their hard work in creating and developing the product.
But to let users know how effective their products are, they have a free version of the software that will let you test its effectiveness in detecting and maintaining the security of your system. But these free versions, of course, have limitations and the full features are only available in the registered version for those who are willing to pay to use it. Here are some of the free antivirus software that you can use:
