Computer capacity and first alert camera software
Hi experts,
Can you inform if first alert camera software necessitates a fairly strong computer to work properly ?
Best regards.
Hi experts,
Best regards.
Your question is quite vague. But if you are asking if your camera’s or digital camera’s software will work on your computer, you just simply need to check the system requirements of the application that comes with your device. Since it is a digital camera, I’m pretty sure it includes its own manual together with the software’s disc or CD.
The description of the program contained in the CD is oftentimes described in details on the device’s manual. Just check the manual for the system requirements and then see if your computer meets the specified requirements of the program.
