Why is my laptop not seeing most devices after I restore the computer to its factory setting? My computer was malfunctioning due to the problem of malware that affect the NIC card. I later restore the computer to its factory setting to clear the malware, but after the restore, the computer stop to see most of my devices. What can I do after downloading many divers for these devices?
Computer does not see many devices after factory restore.
Here are few straightforward suggestions that you could try. What you can do initially is to deactivate and reactivate those devices or uninstall and reinstall. This practice helps the computer to reinstate the memory lost when you performed restoration to factory settings. Lastly, check with the manufacturer, manual or revisit the Terms and Conditions you have accepted if the devices are compatible with the drivers that you have downloaded.
Hello Ronald M Peterson, Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Malware can remove all the important files. It is easy to understand that it can delete any file. There is not a solution to be restore the computer if there any problem is occur, factory restore is totally mistake not a efficient way. If the computer stop to see most of devices after the restore, then there is one solution ,reinstalling the device software. Installing the device software should be properly installed. Sometime drivers that are downloaded from the internet ,they can't work properly, so we should use the orignal device driver.Â
