Hi! System doesn't turn off after I changed processor. Everything was successful, temperature is good, system works perfectly, but after pressing "Turn off computer" only monitor turns off, the rest keeps working. I only can restart system with power button but that's it. Configuration: Intel Core 2 Duo E7500, 2933MHz; motherboard: ECS G31T-M2. PLease advise.
Computer does not turn off after processor changing
Hello, Jonathan!
It must be some kind of bug and not related to the processor, that's why it is stuck. You can try to clear the CMOS. After that back up boot and reset CMOS. It will matter to check all the latest updates for Bios after that.
If you upgraded the processor of your computer, check that the new processor is compatible with your motherboard. You always need to check the specs of the motherboard before upgrading anything. Many things can happen when you installed a component higher than what is supported. Things like unable to turn on, incorrect memory detected, unstable performance, and others.
Intel Core 2 Duo E7500 processor
After checking the motherboard and the processor you indicated, there shouldn’t be any problem. Here are the specs of your ECS G31T-M2 motherboard:
Two (2) 240-pin DDR2 DIMM memory slots – supports up to 4 GB DDR2 800/667 MHz RAM
Integrated Intel Graphics Media Accelerator 3100
Integrated Realtek ALC885 6-Channel HD Audio
Integrated Realtek RTL8111B 10/100 Fast Ethernet Controller
Integrated VIA VT6308P IEEE 1394a (FireWire) port
Four (4) SATA connectors or ports
One (1) IDE connector or port
One (1) FDD connector or port
One (1) PCI Express x16 slot
One (1) PCI Express x1 slot
Two (2) PCI slots
Two (2) PS/2 ports
One (1) 9-pin Serial/COM port
One (1) 25-pin Parallel port
One (1) 15-pin VGA port
One (1) IEEE 1394a (FireWire) port
Four (4) USB 2.0 ports
One (1) RJ-45 Ethernet port
Line in, line out, microphone jacks
Your new Intel Core 2 Duo E7500 processor is pretty much compatible. It is a socket LGA 775 processor at 2.93 GHz clock speed with 1066 MHz FSB and 3 MB L2 cache. If the CPU doesn’t turn off after shutting down the computer, check that the processor is inserted properly. Try putting back the original processor then see what happens.
If it works properly and you can shut down everything, put the new processor again. If the result is the same and you can’t shut down the computer, try replacing the processor or return it.
1....
