When I start my computer, there is an annoying error that won’t stop to show up. I took a screenshot and am presenting it here. I have restarted my computer several times but the error just comes up immediately my desktop shows up. I am running Windows 7.
Error message:
rundll32.exe- Application Error
The instruction at “0x771248c0”referenced memory at “0x771248c0”. The memory could be “read”.
Computer fails to run as rundll32.exe Application error occurred
Hi Leslie
You're experiencing a corrupt file rundll32.exe and it should be replace to do that.
First you need to insert the windows installer in CD or DVD drive
Click start
Click run
Expand X:1386rundll32.ex_c:windowssystemrundll32.exe then enter
Restart
Or to make it hassle free you can download DLL suite it automatically repairs the corrupted DLL.
Hi Leslie,
Perhaps you should try to run to an anti-virus or anti-malware on your machine. It will help you to find out the cause of Rundll32.exe error. You should also try to run a registry cleaner program. You can use this registry cleaner program here. Just run the program, select registry and let the program scan.
I hope this will help you.
