anonymous
7060 points
Posted on - 08/08/2011
I do not know what hardware in computer is. I need a basic concept about the hardware on the basis of what it is.
What types of uses are there?
And what is the importance of these things in modern civilization?
Computer hardwares and the concept of using them on a computer system
Computer hardware is part of your personal computer. Personal computer is made of many components. Parts of computer such as Windows OS, Microsoft Word even antivirus are software. Other parts of personal computer, what you can touch and see is computer hardware.
Every hardware is different because we all have different screens, monitor, speakers, system unit etc. Everything you see inside of your computer is computer hardware, start from HDD, memory and so on. Hardware includes all peripheral devices too, even cables and power supply.
This term came as a way to describe the box and all in it, showing something which is stable, while software represents something which can be changed.
Tinah
Hardware is a device or component, that when connected makes the computer. They are touchable examples mouse, hard disk, monitor, memory card, Motherboard and a keyboard.
lee hung
75 points
The parts of the hardware.
1st is the Central Processing Unit (CPU). It is a microchip that can determine the performance of the computer, through the circuits and the chips that can process faster and it can measure the speed of the clock.
2nd is the keyboard used for typing the information of the computer or maybe to input a data word to Microsoft word. It is designed for typing easier.
3rd the DISK drives and /or Removable Storage used for read a data or information about software from the disk. Then there is the storage device that can used for containing computer files or for installing software and the Digital Flash drive. This output device can put data from the memory cards or store information about the software.
4th the Mouse is used to select an object or text & to access menus of the file of the computer so that it may use software programs.
5th is the Monitor. It shows the outputting information inside the computer and can used for displaying an object from the message on the screen.
6th is the printer. This output device can be used for printing an object or making hard copies.
