I am having some trouble with my computer. It cannot seem to handle the extra load of continuity of use. I am in some serious predicament and need suggestions on how to make my computer better so that it will work or last longer without getting frozen. Someone kindly help me with this issue.
Bryan Edwards
Computer load compatibility error – gets frozen in regular intervals
All the components of you computer must be compatible with each other. Otherwise the program will not run and if run will make various types of problem you faced. Before installing a program you must compare the configuration of your computer. It is also available on the label of the program and even you can see them during installing. The program that is not compatible with your configuration may cause harm to your system. It may go out of order completely. Even you will not be able to install some programs not compatible with your configuration. So take care while installing a program. Otherwise you will face several types of problem.
I hope you understand it.
Thanks
