Sadhbh
Posted on - 10/12/2011
I bought my computer (Lenovo) from 2 years, and I work so good but recently there was a problem that every time I start it computer begin with making noise and I do not know which part make noise.
So please anyone tell me how to know which part of my computer is making noise.
Computer making noise how to stop
Normally When the computer is turned on and it is making noise is because of the power supply fan. You have to check the fan of your power supply that any dust is there in or not.
Open all the screw that are on the casing and then turn your computer on if and keep listening the noise that from where it is.
It must be the power supply fan. If the power supply fan is making noise then what you have to do open the power supply from the computer and put some oil in it to make it easily rotate. the noise will be no more. thanks for asking in techyv.com.
Thanks
Try the solutions below in this problem of yours it might help you solve your problem:
Solution 1:
If its on boot up then check your F8 button if it is stuck because normally it makes a non stop noise during boot if you continually press the F8 button. You might have press it to hard the last time you try to put it on safe mode.
Solution 2:
Check your memory and try changing it with a different one or try inserting only one memory if you have more than one memory for your laptop. It could be the source of the noise. You computer in this state only turning on without displaying anything in the monitor.
