Computer is Making Weird Sounds
There is something weird going on with my computer and I can’t find the cause.  The problem is that I hear sounds like ads or even radio conversations even if there are no programs running.  I have scanned my computer for Malware and Adware but didn’t find any, it’s clean.  Can somebody please give me a solution to this? Thanks.
Answered By 0 points N/A #102447
Are you hearing those sounds while your browser is open or not? I am suspect that your browser may be open, and then some pages are opened which have the videos or the audio files that are playing on them. You will therefore need to check the tabs that you have opened in your browser and close those that you find have movie or audio files playing on them.
Otherwise it could have been some background process that you have set to start automatically when you boot your computer. To see an application like that, you will need to press ctrl+alt+del on your keyboard to open the task manager and then under the processes tab, look for any processes that you suspect are responsible for that and close them.
-Lee Seen
