PC won’t turn on with beeping sounds
Hello people,
I hope you guys can help me about my computer. We have an old computer with very low specifications. The computer was still working yesterday and my brother was still able to play a game using it. But this morning, when I tried to turn it on, it cannot display any picture on the screen and I can hear a "beep" "beep" sound on the CPU.
Can anyone please help me?
Best Answer by kimanif
Answered By 0 points N/A #98537
I think I already know your problem. I also experienced that with my new computer,  I heard the sound BEEP three times. And this is also my problem in my CPU, but I solved said problem  when I opened my  CPU and cleaned it inside. After I got the dust out, I closed the CPU, then It worked!.
Notice!! If you're done playing or using your computer, you must SHUT IT DOWN so that it will turn off slowly and not quickly. Because the CPU or the computer will not function and it will make a sound BEEP BEEP BEEP.  This also applies on the light at the back of the CPU that has a color orange and sounds like BEEP BEEP BEEP.
With best Regards,
Analie
Answered By 0 points N/A #98538
For you to solve the problem you have to blow out the dust in your computer. Secondly remove the RAM for about five minutes and fix it again. Still that’s not enough if you look on you Motherboard you can spot a small battery even that you have to remove it for about 5 to 10 minutes then fix it back.
  • After you finish that, check for any loose cables like the one from the power supply to the drives and also the data cables.  Dust is enemy to machines especially the Motherboard.
  • When you finish all that I believe your computer will good as new.
Francis
