Computer not starting problem in desktop
Hey Shamsroyal!
If you are trying to start your computer and you are not viewing anything on your computer screen except a beep sound from your CPU, then it must be the problem of your RAM. Your RAM is not working properly. If you are using Two RAMs, try to change their places and start your computer. If your computer does not starts then try to insert only one RAM at a time and start your computer, If your computer starts with one RAM, it means the other RAM is not working.
If you have only one RAM in your system then you must buy a new RAM for your system. If your Ram is in warranty, claim your warranty.
Thanks
If your computer won’t start and it gives you beeping sound or sounds, then most probably there is a hardware issue. The question is how many beeping sounds and how long are the beeping sounds that you hear? Did you hear long beep sounds, or were they short ones, or both? If you are not sure, please try to restart your computer and take note of the beeping sounds that you hear. Meanwhile here are some websites that might help you determine the codes for those beeping sounds, which part of your system might be causing those beeping sounds, and how to get them fixed:
https://www.computerhope.com/beep.htm
https://www.lifewire.com/how-to-troubleshoot-beep-codes-2624889
Beep codes are used to detect initial errors on the system of your computer. If you’re hearing beep codes after you turn your computer on, it means that the system encountered some kind of problem before it was able to display error information. Each beep codes represent different system problems.
To determine which problem of the system the beep code is representing, just follow these steps.
1. Power on the computer or restart if it is already on.
2. Listen very carefully the beeping or restart your computer if you want to hear it again.
3. Take note or write down any significant observation especially how the beeps sound. There is a big difference between “beep-beep-beep” beep codes and “beep-beep” beep code.
4. What steps you take to solve beep code problem will differ depending on the BIOS manufacturer. Choose the correct beep code troubleshooting guide based on BIOS manufacturer.
To determine your Motherboard Bios manufacturer, click n this link.
Hope this will help you.
Hi Tunacao_Caaron1!
Your solution actually worked! I did all the troubleshooting I know before and nothing worked… A week have passed and I was still hopeless.
Good thing I was able to find your solution. My techie friend helped me with all those "RAM" works since I'm kind of new to it. Now, everything seems to be working fine. Thank you so much! 😀
