The Computer problem black screen?
When my computer starts a black screen appears with this message:
"Warning!!!
The previous performance of Overclocking is failed, and the system is restored to the default setting
"Warning!!!
Hey Rasel.
Upon receiving this message, are you entering setup? Or are you just rebooting? If you haven't entered setup, you need to do that. If you changed settings recently, you need to change them back. If you didn't mess with the settings, and have no idea what to do to fix this problem while in the BIOS, you can hit the appropriate key to load setup defaults. This is usually "F9" on most computers. to see which key actually loads the defaults, hit F1, which will bring up a help menu telling you which keys do what.
After loading default settings with the appropriate key, hit F10 to save and exit the BIOS, which will restart your computer. If it does not work then try resetting the CMOS and everything should be fine. Chances are there was an issue with the information stored in the CMOS that cause the error. This is how you can do it; Open your CPU there you will find CMOS battery remove it and reinsert and there will be a BIOS pin remove it and reconnect. Now Switch On the System.
If you still have problems after CMOS reset then there may be an issue with the motherboard.
Regards
Hi this kind of issue due to the defect of computer hardware, to solve this issue replace your CMOS battery and try to used multi-tester then check the Voltage of cmos battery, the voltage must be in 3 volts.
If the voltage is only 2 volts you need to change that to new Cmos battery.
If this option will not work, you need to consult that to the Computer Technician to fix the problem of your computer hardware.
Thank you;
Regards;
Henjov22
Notifications
