Computer reboot during a BIOS reset
The genuine BIOS can be reason of damage for this sort of difficulty. One way to resolve this difficulty you must substitute or rearrange the BIOS. Sorry to say this can damage your computers Flash BIOS reason your computer to no longer boot appropriately. It may be achievable to restore the default BIOS setting with a number of computer motherboard.
To observe if this is achievable by using a jumper on the motherboard this refers to computer manufacturer or motherboard manufacturer manual. Regularly Jumper will be labeled as rearrange BIOS. Check does your motherboard have a jumper? If not then contact with the motherboard manufacturer or computer manufacturer for more suggestion or a substitute BIOS chip.
Hello Ripon,
To update the BIOS settings you will need to access the BIOS. You will need to use the following simple procedure:
This will surely help.
__
Lee Hung
