Computer restarts randomly, please help
Hello Evans Hopkins,
This is most common problem of the computer. If you are always playing "Hitman Blood Money" please make sure to clean your cookies and Internet browser after playing. It is just occupying some of your memory.
And always check your CPU if there's a lot of dust or dirt, it can be cause of overheating that's why your computer automatically restart.
I have here some of the solutions, please do any of the following to fix the problem.
Solution 1
Clean your cookies and Internet Browser, every after you play please do this method regularly. So at least you can avoid automatic restart.
Step 1: Press the Windows keys > Control Panel > Network and Internet Connections category –> Internet option icon.
Step 2: On the General tab, please check the Delete browsing history on exit check box then click the Delete button.
Step 3: Kindly check all the check box to remove Temporary Internet files, History. If you doesn't want to remove passwords or Form data, it's up to you.
Step 4: Wait for a second then after deleting the files, close the dialog box.
Solution 2
Have you ever try to clean your CPU?.. If not and there's a lot of dust or dirt, better to clean them. It can cause of overheat, clean also your memory RAM. These is the steps on how to clean your CPU:
Step 1: Open your CPU, remove the cables, connectors, hard disk drive and CD/DVD Rom.
Step 2: Get a soft cloth to remove dust and dirt.
Step 3: While the cables and connectors are remove, clean it with your soft cloth.
Step 4: In cleaning your memory RAM, get eraser to rub the golden surface. Then get a soft cloth to clean the particles of eraser. Now insert it to your computer after you clean them.
Step 5: Insert the cables, connectors, hard disk drive and CD/DVD Rom. And run now the computer to check if automatic restart is already resolve.
Solution 3
In this solution you are going to restore your computer from the very best day that your computer doesn't face any problem. Using System Restore helps you to back the previous day before you got problem on your system. Follow these steps:
Step 1: Run your computer into Safe Mode by pressing F8 key during the initial startup.
Step 2: In the Windows Advanced Option select Safe Mode then hit Enter.
Step 3: An in the startup the Desktop dialog box will open then select NO to proceed in System Restore.
Step 4: Select Restore my computer to an earlier time radio button then click Next button.
Step 5: In the calendar choose the day before when computer is working in a good condition then click Next. And the computer will automatically restart.
Solution 4
Set the Turn off the Automatic Restart under the Startup and Recovery. Follow these steps:
Step 1: Run your computer into Safe Mode, follow steps 1-2 in Solution 2.
Step 2: An in the startup the Desktop dialog box will open then select YES.
Step 3: Right click My Computer –> Properties
Step 4: On the Advanced Tab, click Settings under Startup and Recovery.
Step 5: Uncheck the box with Automatic Restart and click OK
Step 6: Then restart your system in normal mode.
Solution 5
Having a lot of applications and programs that installed in your computer, can be the problem why it's automatically restart by it's own.
It remains in the memory if it is too much for the memory to handle, that you are running too many applications, programs and running many browser. If you are using multimedia user, having a lot of applications and programs, I suggest you to upgrade your memory at least 512Mb of memory. So you can avoid automatic restart also computer hang up.
Solution 6
Set the System Standby by Safe Mode method. Follow these steps:
Step 1: Look for the Solution 3 and follow the steps 1-2.
Step 2: On your desktop, right click to select Properties then select the Screen Saver tab.
Step 3: Click Power button under the Monitor power.
Step 4: Under the Power Schemes tab look down to System Standby then from the drop down list click NEVER.
Step 5: click Apply > OK.
And please also set the Monitor to turn off. Follow these steps:
Step 1: On the desktop, right click > select Properties.
Step 2: Then in the Screensaver Tab > click Power.
Step 3: In the Turn off monitor drop down list > click NEVER.
Step 4: Click Apply > OK then restart your Computer.
