This computer’s Internet connection appears to be online 66559
Hi Experts,
Hi Experts,
Hello Aabel,
Use the following quick fix to resolve the issue:
Nicke
Hi Aabel Maverick,
I have found the best solution for your Issue. This problem is related to the internet connection speed fluctuation. Be sure your connection is in working condition.
First of all clear all temp files for good internet connectivity. Use this procedure for clearing temp file:
1. Press Windows button + R
2. Appear new box below. Write %temp% inside box and hit enter.
3. New window open, press ctrl+A for selecting all files and delete all files.
4. Close all windows and restart your system.
Then again try to play same video. It works.
I wish this solution may be helpful. Thanks!
Best,
Fenster Maxine
QuickTime is a great media player that I use. I’ve experienced this type of error when my internet connection was sometimes interrupted. After searching the web, I’ve found the solution here. Thanks to both experts for giving me nice solutions, but I especially appreciate Fenster Maxine’s suggestion, which helped me solve this problem. I love QuickTime very much.
If that particular video you are trying to watch is online, the problem could be with your internet connection. Since you are watching the trailer with QuickTime Player and not directly on the website, it might be a problem with a lagging connection. First thing you should try is troubleshoot the cable.
Disconnect the network cable from the network port on the side of your laptop then plug it back in. If this doesn’t work, disconnect the other end of the cable from the Wi-Fi router then connect it back. If this doesn’t work or you connect to the router via Wi-Fi connection, try restarting the router.
If the router has a power button, press it to turn it off then unplug it from the power for about twenty (20) seconds. Press any button on the router to discharge any leftover power or to power cycle. After this, plug the router back to the power and turn it on. If the problem continues, contact your network provider for assistance.
Notifications
