PeteCashmore 0 points N/APosted on - 09/26/2011
I work in computer many hours per day and in the previous days while I was working my pc shutdown many times and I lose my work so I do not know what is the problem and can’t stop it.Â
Actually, there are many aspects why your computer shuts down automatically. One of this is the overheating of your system. It overheats because of too much dirt and dust.
Another one is short circuit or voltage problem. These aspects turn your computer to automatically shut down. Viruses can also cause your computer to shut down because it corrupts your files including your drivers.
These are the factors and aspects that cause your computer to shut down. In order to avoid computer shut down, you should learn to take good care of your computer. You should clean to your computer every day.
If your computer shuts down because of these aspects, it is good to just stop using your computer temporarily.
Hope the information written above could help you in your problem.
If your computer keeps shutting down randomly, it could be a problem with the cooling effect of the CPU. Normally, the computer shuts down automatically when the temperature of the processor reaches the peak level. This is to avoid damaging the processor. The temperature of the processor is controlled and maintained by the CPU cooling fan or the cooling fan attached on top of the heat sink.
CPU cooling fan and heat sink
The speed or cycle of the cooling fan is controlled by the BIOS. In other computer brands like Dell, the speed of the CPU cooling fan is automatically changed by the BIOS as the temperature of the processor rises up. The speed is controlled based on the current temperature reading of the processor.
In your case, if the computer keeps shutting down, try increasing the cycle rate of the cooling fan. Restart your computer then press DEL, DELETE, F2, or whichever key is used to go to the BIOS. In the BIOS, navigate to the power management section then locate the settings for the CPU cooling fan. Increase the value for the CPU fan, save the settings, and exit.
See if this works. If this doesn’t work, try replacing your CPU cooling fan with a new one.
RICH Miner officially launches a new mobile cloud mining application, subverting the traditional mining model! No need to buy mining machines, no technical experience required, just a mobile phone, global users can start the...
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
