Computer Slowness Issue
I am writing about a small topic, the slowness issue we usually face with both computers and mobile phones, due to excessive storage of cache and temporary files, and how to get them cleared?
With everyday use of computers and mobile phones, each application that we run, generates a certain amount of cache files and temporary files required for it’s functioning, but after that function is over, these files remain in the system storage occupying space and RAM memory, thereby decreasing the performance of the system. A simple solution is to delete them on the occasion when you feel the system is slow, this can be done by typing “%temp%” in the Run command bar, select all the temporary files that come up and then hit the Shift + delete buttons to permanently clear all the temporary files.
