Baird
Posted on - 11/07/2011
I took Computer Program lesson about MS Office v2007. But I’m still using MS Office version 2003. Could you recommend at least 3 latest software programs in terms of Word-processing? I also would like to ask what brands do you recommended which would suit my needs. It should have the best featured Price Security Program, aside from support for on-line financial transaction.
Computer Software & Programs-Staying on Track
Hello Baird,
Some of the most common word processing programs are the Microsoft word whose latest version is the ms word 2010, the notepad, the word pad and the open office editor which a Linux based suit.
For you I will recommend that you go for the latest Microsoft office 2010, as it has very diverse features compared to the others that I have mentioned that will give you the best outcome for a document you need to create. Although ms word 2007 seems to have many features that are in the ms word 2010, the ms word 2010 has more which are even more refined hence making it easier for you to use them.
So if you want to gain more exposure in using the word processors, I will recommend that you go for ms office 2010.
__
Regards
Clair Charles
