I am really tempted to get a new laptop. I am planning to pursue my passion for taking pictures and edit them. I need the laptop to be able to support heavy photo editing software. What are the hardware specifications and features that I should look for and consider before buying?
Computer specifications needed to support photo-editing software
Hello!
The specifications and features of the laptop that will support your work in editing pictures are also depending on the apps that you are going to use. The operation of app needed for your work have unique system requirements and system sources.
Example of these system requirements are the following
I recommend the
Shutterbug site for more details.Â
If you are planning to buy a photo editing software and want to know the suitable specifications of a computer for this job, that would depend on the application you will be using. Since you want a software that’s best for editing images, you can try Adobe Photoshop Creative Suite 6. It supports Windows XP Service Pack 3 and Windows 7 Service Pack 1 including Windows 8.x.
It requires Intel Pentium 4 or equivalent AMD Athlon 64 or faster processor, 1 GB RAM, 1 GB free space, 1024 x 768 minimum screen resolution, and video card with 512 MB video RAM and OpenGL 2.0 support. If you want a much newer application, you can try Adobe Photoshop CC. The latest version at the moment is Adobe Photoshop CC 2015.x.
It supports Windows 7 Service Pack 1, Windows 8.1, and Windows 10. It requires 2 GHz Intel Core 2 or equivalent AMD Athlon 64 or faster processor, 2 GB RAM, 2.6 GB free space, 1024 x 768 minimum screen resolution, and video card with 512 MB video RAM and OpenGL 2.0 support.
Adobe Photoshop CS6 is a standalone application that you can buy for a one-time fee for the license while Adobe Photoshop CC is subscription based. For more information on Adobe Photoshop CC, go to Adobe Creative Cloud.
