giddeo
20 points
Posted on - 08/14/2011
Why there does not exist any charge storage option in computer? That cold be used for about 5 to 10 minutes after sudden disconnection of electricity, so that one could shut down computer properly. In simple word, computer should have the facility of uninterrupted power supply integrated with C.P.U at least 5-10minutes.
regards,
Giddeo
Computer System Should Have Backup Charge
Hi Giddeo,
It is not true that there is no way to back up charge for your computer. In order to have a back up power for several minutes you can use UPS with your PC. Connect the main power from electricity board to UPS & then connect your CPU to the UPS.
There are several UPS available in market that will allow you to backup your power for up to 30 minutes. SO if you have any unfinished work or any unsaved work you can complete it & then shut down your computer properly.
I hope I am able to help you out.
Thank you
It depends on your requirements and your environment also. If there is some fault in your electrical supply this is not a computer fault it is a power supply failure and you can arrange it as per your requirements. You can arrange a UPS for your computer or you can buy a laptop which supports a battery backup of almost one hour so you can arrange on as per your requirements. There are also some cheep UPS supply which can help you in your work the backup time for such devices will be five to ten minutes and you can buy it for your requirements. If you need to save work every time then you can buy it and it will help you to save your work after the power supply failure occurs.
The other solution for this is to shut down your computer every time when there is some hours fixed for supply failure if you are well known to hours for shutdown then you can manage it as you can shutdown it before the supply failure and your work will be saved properly moreover save your work time by time so it you don't loose your work.
