Computer tell file missing or corrupt.
This type of problem can be occurred by the inaction of virus or the bad hard drive. if your hard drive is too old and it has many bad sectors it may be causes this type of problems. So you need to re-install that program again or download the application again and install it again. there also another reason your any windows file is missing or any windows file is missing by any virus so you have to re-install your windows and it is the better path to success. If you do not have a registered anti-virus to solve the problem you can buy a antivirus. Thank you.
There were only two reasons how a file could be corrupted. First is a physical reason, it might be a bad cluster or a bad block or a cause of improper using of computers.
Physical reason are un-predictable, this are cause of wear and tear operation. So it is the hard drive that needs the attention to fix or replaced.
Improper use of computers includes improper shut down and allowing removable media to be inserted in your computer without scanning the media for possible virus infection. Viruses may cause file corruption by imbedding its code in your system. Virus cleaning is the solution for this or performs a system recovery.
