Computer Throws Application Error 0xc0000142
I download the application but when it downloads my network is not working after download it I unable to open it when I open it the popup comes with application error 0xc0000142 so I want to know, What is application error 0xc0000142? How to fix application error 0xc0000142?
Answered By 0 points N/A #332620
The program that you are using is corrupted then the application error 0xc0000142 occurs. The error occurs due to corruption and the damage of the files which a rare computer and application use. This will make your computer unreliable.
Steps to fix application error 0xc0000142:
Method 1:
1. First, press the windows+R then on the run dialogue box type regedit.
2. Now go to the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows NT\ CurrentVersion\ Windows\ LoadAppInit_DLLs.
3. Then double click on the LoadAppInit_DLLs and set the value to 0.
4. Now click on OK then confirm and exit.
Method 2:
1. First, right-click on the application icon and click on properties.
2. Now click on the Security tab.
3. Then check the box Run this program in compatibility mode for;
4. Now in the drop-down list select the operating system.
5. Click on Apply and OK.
