Computer Turn off by itself
When I want to open Photoshop 7 in my computer, the computer is going off and takes more then 30 minutes to restart if I want to switch it on. I don’t know why this problem is appearing. I want a good solution for this problem.
Best Answer by cniket
Answered By 0 points N/A #109136
There could be many causes behind this issue. I may help you explaining the causes with solutions:
  • Computer Configuration:
Check you computer’s configuration, if the processor itself is very old or the memory (RAM) is small/low then the computer may take time to re-boot or keeps freezing when try to open any program/application. Try upgrading the memory (RAM), and reboot your computer, check the performance.
  • Viruses, Spyware, Malware:
Check and clean your computer with the software called Malware Bytes to clean your computer from spyware, check and clean your computer with the virus software.
  • Tune up Utility:
This is the software which helps improving the performance of PC and helps defragmenting the hard drives and many more. Go to Google and type in for Tune up utility get you to the website and lets you download the trial versions.
