Computer’s BIOS password break & troubleshoot
I am giving clue on only two options. But there are many ways to solve this problem. I don’t know that your motherboard from which company or brand. Each company has different option and control system on BIOS (Basic Input Output System). But the main method is same. So you can apply this option.
When computer starts try to enter into BIOS. When motherboard’s logo came press f2, f8 or delete button. Different company have different dedicated key for this. In here try to find a option called “Optimize default” or “System default” whatever it is just press enter on it and save the change then restart computer.
Other option is you can remove BIOS password by opening motherboards CMOS for a few moment. This will reset your BIOS and remove all passwords along with all settings.
The simplest way to do this is to gain access to the motherboard and remove the battery. You have to wait until that capacitors lose their charge so that all user settings are lost.
Some motherboards have 2 pins that we shut in order to lose all BIOS user data.
If you don't find it, you just keep the 3 Volt battery out for 15 minutes or so. After this amount of time, the capacitors load is probably over and all data is gone from CMOS memory.
Insert the battery, avoid fingers on it as skin oil can corrode and isolate it, and all passwords are lost when you start your machine.
Cheers!
Hi Rabbi
There are many procedures to resolve this issue. Here provided all procedures are good but have many ways to resolve this issue. Pay a visit this Techyv link to get more idea.
Notifications
