Computing the Total Frame Frequency
40 points
Posted on - 10/28/2011
I need help on computing frame rate. The situation is, if multiplexor A and B will integrate to sum up 100 Kbps channels by using a time slot of 4 bits and each frame produced from A and B with 16 bits and frame in C is 32 bits, what is the total frame rate for this? I’m calling for help.
Thank you.
