What are basic drawing tools available in it? Has it any web element, such as Table, Hyperlink, Text? Can I use Div here? What are drag and drop shapes? Is there checkboxes, radio buttons, combo boxes available? How can I change the button name, text or color property? Can I export the document to Pdf, Png, and JPEG format? How to use Cliparts into it from the Internet? What is Diagram Drawing Support in it? Is it windows based software or Can this use any other operating systems? Thank You
Concept of Pencil 2.0.5 software and its benefits
It is one of the application process help you prototype GUI's for your application. The user interface ranging from desktop to mobile platforms.
There are many parameters welcome by well organized functions. At the same time multiple instance runs simultaneously.
The generated design is PNG, SVG and ODT format. The clipart.org is to find clip art and add into the drawing.
The final conclusion is pencil software is proven to be a reliable application that is generated by special features helps us design user interface design (GUI). It really makes an ideal tool for rookies and professionals alike.
