cleo patts
Posted on - 12/10/2011
I am customizing my Calendar in Outlook. I made some conditional formatting so I can see those meetings that I prioritized and to easily distinguish if I need to travel for a meeting. But I found out that the conditional formatting doesn’t work for most of my meetings. However, it works for other entries. What is the reason for this and how can I fix it?
Conditional Formatting Issue in Outlook
Hi cleo
Outlook calendar notes will serve in its administration way. If you have that activity, you can run by it. The supported administration is going through MS Word. At first you should create an account in the installed MS Word Outlook. Remember your program must register or you will fail to run account. Then sync on your PC this recognize your system rapidly. After save the program and note which you will want to lounge.
So you have to take first account in this MS. W and the entries you save as note will clearly describe on the Outlook or Access. Keep it up
Regards
