johan weiz
20 points
Posted on - 03/30/2012
I recently change few of the video settings on my vlc media player and the screen is vertically parted by a damage in the middle. I cannot fix it with the configuration settings. Should someone know of this problems kindly inform me as soon as possible.
Johan Weiz
Configuration changing made the screen portion on media player
If that is the current condition of your VLC media player, the application really has a problem. Uninstall the application from your computer. Next, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit or Norton SystemWorks. After checking the hard drive, install VLC media player again. Open it and check if it is already fixed.
If you are using an older version of the media player, try upgrading it to VLC media player 2.0.1. You can download this application at https://vlc-media-player.en.softonic.com/. This version is compatible with Windows 2000, Windows XP, Windows Vista, and Windows 7 platforms.
