Configuration Error Which are located outside Drive C
I was using IIS7 Manager to update the settings of web.config of several of my sites.
I noticed that this problem only happens for sites that are located outside my C:inetpub folder.
So I transferred some websites that I had setup in my drive E:.
This didn’t help, and the error keeps on showing up.
Can someone please lend me a hand?
I attached a screenshot of the error notice, here.
An error occurred while performing this oparation.
Details:
Filename: \?E:My ProgrammingCcRecommendertrunkCCRecomendatorCCRecomen dator.WebUIweb.config
Error: Cannot write configuration file
Thanks Need help.
Souvic
