Configuration Manager error Input string was not in a correct format
Hi there,
I try to install the Configuration Manager 2012 console on a workstation with an existent Configuration Manager 2007 console you will have the following error message. I would like to have the both versions and I don’t know how to make it works. Can anyone help me to fix this error? Is possible to have two versions of System Center?
Thanks guys!
Input string was not in a correct format.
OK
