Configuration of SMplayer in Linux Mint 13 for HD playback?
Asked By 7060 points N/A Posted on -
I have an Intel GMA 495 graphic chip on my laptop and I am experiencing troubles with HD video playback on it using Linux, while on Windows everything works fine. I have the most update version of drivers and X.org. Are there any opportunities for fine-tuning the video player to improve the performance?
Best Answer by Copeland Hughley
Answered By 0 points N/A #85071
Hi!
If you are in Linux Mint 13, then you are using mplayer under smplayer. Smplayer is only a graphical user interface for mplayer. When you are in windows and if you have the latest smplayer, you are actually using mplayer2. Now, you can't update mplayer to mplayer2 in linux mint using the default distribution packages. You can install mplayer by downloading or cloning the git file from the website of mplayer2. Here is the link to the download page mplayer2.
I suggest you use the file mplayer2-build.git since it will also update some libraries used by mplayer.
You can clone the git file by typing this in terminal.
git clone git://git.mplayer2.org/mplayer2-build.git
Just be sure you have git in linux mint. You can install it from the repositories.
Answered By 15 points N/A #85072
Hello buddy,
A convincing level of dispensation authority is essential for even DVD playback. The scheme supplies in Linux are much higher than in Windows, since a lot of the techniques used for hardware speeding up of video playback work only in Windows. I advocate the following.
To create a representative link from /dev/dvd to the definite hardware device on behalf of your DVD-ROM drive (which in this example is /dev/hdc, but you are supposed to replace it with the definite device file second-hand by your drive). The /dev/dvd link is not only a substance of expediency; approximately all of the actor software mentioned in this HOWTO assumes that the link is there.
  • 700 MHz or higher CPU,
  • video card with X Video Overlay support
  • DVD drive with DMA enabled
