Configure Mouse X3:TC Speed and Sensitivity
Does anyone have an idea on how to configure the speed of the mouse arrow in X3: TC? Is the mouse arrow sensitivity set, or can it be changed and set to be more sensitive? I find it very slow and passes through the menus rather slow. Sorry if this has been done before, I am trying to find the solution to this and I hope this forum can help. Thanks.
Best Answer by Experttechyv
Answered By 5 points N/A #114531
The speed of the mouse is directly related to both game lag and the DPI rating that the mouse has, and therefore a slow mouse may mean that there is a high-lag, or it could also mean that there is a low DPI rating. A jumpy mouse on the other hand may be behaving that way because there is a high lag, or there could be a high DPI rating.
So in your case, the game lag might be the problem, and you will establish that if you find the PC is a little dated and therefore refusing to carry out some operations like playing certain games. You may not see sluggishness in the mouse with some operations but to others the cursor may just move a little.
-Experttechyv
Answered By 5 points N/A #197865
I think you are using a high graphics resolution which is not supported. If you want to try out you can change your mouse settings in the Control Panel. You can try out changing your screen resolution and then try out the mouse speed. I generally think this is resolution fault otherwise change your mouse.
Hope this helps
