Can any one help me how to configure both end of the twisted pair cable in EIA standards.
Thank you.
Configure a Pair of Twisted 8-Position Modular Connector RJ45 Cable
Hi rachel,
Both the T568A and T568B standard specifies a particular pattern for arranging the wires within the RJ plug.The wiring arrangements are listed below.
T568A (the first end of the cable into RJ plug)
wires                Pin number on the jack
white/blue               5
blue/white               4
white/orange             3
orange/white             6
white/green              1
green/white              2
white/brown              7
brown/white             8
T568B (the second end of the cable into RJ plug)
white/blue              5
blue/white              4
white/orange             1
orange/white            2
white/green             3
green/white              6
white/brown             7
brown/white             8
Please make sure after entering the wires into RJ plug of one end press the RJ plug with crimping tool.
Hi RachelÂ
It is quite simple to get mixed up and always be sure that when inserting the cable into the jr45 plug that the clip part of it is facing down that way pin one will always be on the left.
Also make sure the wires are cut straight and go all the way in.
Attached is a file with the colour code for the RJ45 connectors (TIA/EIA 568A and TIA/EIA 568B)
Hello Dear,
There are two types of cables used in networking.
Cross cable
Straight cable
If you are linking two same devices with one another then you have to use cross cable. Configuration of cross cable is as below.
=========>    First end of cable   <==================
1. White orange
2. Orange
3. White green
4. Blue
5. Â White blue
6. Green
7. White brown
8. Brown
========>  Second end of cable   <=================
1. White green
2. Green
3. White orange
4. Blue
5. White Blue
6. Orange
7. White brown
8. Brown
But if you are going to link two different devices then you have to use straight cable.
=========>    Both end of cable   <==================
1. White orange
2. Orange
3. White green
4. Blue
5. Â White blue
6. Green
7. White brown
8. Brown
Thanks
