Configure VPS & cccam with PC
I want to configure VPS with cccam & a card reader with my Personal Computer which has windows xp operating system & most importantly is it possible to hide my IP with VPS?
Dear Marilyn Creeves,
You have two ways to configure VPS. The first one is by choosing the default setting for your VPS, the default setting which make it run on Windows XP without any problems.
The second is by making a custom setting by choosing your personal configuration during the installation process. Settings can also be customized after installation. At the Option tab, go to the Configuration button and select to hide your IP button.
Hope that was helpful for you.
Best regards,
Don Muench
