Configuring a gadget ip finder to locate a gadgets previous ip addresses
How can I configure any specific gadget ip finder to identify previous ip addresses for a mobile device in case of roaming or a change of ip addresses for various specific reasons by the users?  (please specify the gadget ip finder's name while answering)
Best Answer by LyanaHay
Answered By 0 points N/A #139004
Weather Badge detects your location by IP address.  Another IP finder Visitor World map that display a Visitors IP Address on a World map. Even more some of the IP finders are Portal Romances, Hit Counter, G.Map – Your Location, Visitor IP Address City etc. I hope you get the answer.
Answered By 0 points N/A #139005
Hello Jean,
 I think instead of going for applications for finding ip address while you are i roaming i will suggest you to get some website where you can find your ip address much easily.
Because these software’s are much expensive as compared to websites. There are few software’s which can keep track of your device. Like IP Locator.
But I will suggest you to make account at some website where you will get same results for free.
