Configuring Lock Folder App for Android Device
How to set up android lock folder app pro? I have some files in a specific folder that has to be encrypted or given a password because of confidentiality purposes. I hope you can give me a step by step instruction to be followed.
Waiting for your support, thank you.
Best Answer by Parthy Goan
Answered By 0 points N/A #183670
Hello Christine Yong,
There is a variety of software for security and encryption of folders in android OS. You can use App lock which works great on Android version 2.2 or later ones. Just download it from the Google Play Store or Market and install it in your phone. It is not complex at all in use. It will ask you everything at the first start and you can configure all options according to your desires.
Answered By 5 points N/A #183671
Hi there Christine:
A lock gives us mobile privacy, how great software developers are! You just need download it via Google Play store and I can tell you that is not complicated to set-up. While you install it, instruction and options are to hit. It’s up to you, user, how you want to use it, how you want it to look like. It’s easy when you already have it.
Thanks for asking via techyv.com
