Configuring SigmaTel Audio Driver and Applications Exit error
Restarting my PC is not helping to solve this error. Nothing that I can do and I know works. After I updated my Windows I can’t install some of my drivers. What is the best solution for this kind of errors? How can I solve this one so I can listen some music?
Thank you!
ExitError:Error= Device Object not present restart the system and run setup again
OK
Answered By 590495 points N/A #188398
It depends on what kind of update was done on the computer. If you only installed an update from Windows Update then you probably just need to reinstall the application causing the error. But if you upgraded your operating system’s Service Pack, then reinstalling the application may no longer help unless it still supports the current Service Pack.
If the problem started after installing a Windows update, uninstall your soundcard then restart your computer. Update your Windows again via Windows Update. Install any available update, restart your computer, and then install your soundcard again. See if this works. If your soundcard still doesn’t want to install, download the latest version instead.
Visit SigmaTel High Definition Audio Codec to download the latest version of the driver.
