In my office. We are having couple of broadband connections. One broadband system for all users and other for a specific computers. Connection 1 stop and we try to move all computer on the other but its not work. Reason here conflicting of IP.
Whether it needs any further procedure?
It differentiate the IP? Or whatever?
Guide me the whole procedure.
Conflicting of IP in Server with different broadband services
You Can Use The NetScan Software For Scanning The Whole IP Selection And Then Checkout the Computer Names Which are Conflicting on The Same Ip's Cause its a Common Problem That When Pc's are Connected Locally.
Then Ip Conflict Error Occur!
HELLO
Conflicting IP address problem is easy to solve it, This problem belonging to the name of ip address on your computer , you must change the name of your computer by pressing right click on my computer then Properties and press computer name, put another name and restart the computer, and if this does not solve the problem change the last number in your ip address and this in case you have ip address then restart the computer.
I hope that be helpful for you.
HI,
You are facing this problem because some computers hold same IP Address. You have to define only one IP Address for one computer. Change the IP addresses which are common and try again to connect. Hope your problem will be solved. You can also use DHCP connection for defining a particular IP for one computer; In DHCP connection computers automatically update its IP Address from the available IP Address.
