Confuse about my operating system
I installed the same operating system (Windows XP) on my computer after the old one crashed. How am I supposed to know which disk/drive IM running my current Operating System and how to remove the old one?
If you are get confused about your operating system then i will suggest you a simple and very easy solution. Some people might take it a stupid answer but i think this is the best solution ever. Two method if you have some secure data that you want to lose the what you have to do.
Insert into your Cd room and select the partition in which you want to install it will search for the old Operating system if it found any Old version of the operating system it will display an option asking your that Older version found format that version and install a fresh copy.
Hope you will get my point.
Hi Cverg,
Either you have two XP in different or same partition in your HD, every time you start your pc, you will find prompt to pick one of your XP. the prompt similar like the picture below:
In your case, you got double "Microsoft XP" on your prompt, right?
Btw if you install OS in same partition, skip this step below.
Now you know, the top options of the OS prompt is in the drive letter you find in windows command prompt.
Now you're ready to remove the old XP.
Follow this steps really carefully. Save and back up all your important data before format your HD.
Finish.
O yes, if your XPs both installed in one partition, you just need to insert your CD Rom XP, formatting your XP partition with CD installer, then start clean install.
Notifications
