Confused with HTC Sensation XE
I was confused with this HTC Sensation XE.
When it comes to its tones because some people said that its sounds is too loud.
How this gossip true?
Yes it sounds to laud. It sounds too loud if you are going to use iBeats headphones. This HTC mobile has a settings or option if you want to play music with Beats Audio switched on or off.
If you turned on eats Audio, the music has bass and the treble also will turn to the max volume.But most of people who use it preferably turn off the Beats Audio, because it much tiring to listen music when Beats Audio is turned on.
Most users use android version of Winamp which they said make music sound less and good to hear.  But if you talk all around about this phone, you’ve nothing to complain.
The HTC Sensation XE supports 2G and 3G networks only. 4G is not supported. It was unveiled on September 2011 and released on October 2011. It measures 126.1 x 65.4 x 11.3 millimeters and weighs 151 grams. It has an S-LCD capacitive touchscreen display with 16M colors and 540 x 960 pixels screen resolution. The screen is protected by Corning Gorilla Glass with HTC Sense UI and supports multi-touch.
It runs on 768 MB RAM with 4 GB internal storage where 1 GB is available to user and microSD upgradable to 32 GB. It supports microUSB 2.0 [MHL] and Bluetooth 3.0 with A2DP. The primary camera supports 8 megapixels at 3264 x 2448 pixels resolution featuring autofocus, dual-LED flash, image stabilization, geo-tagging, touch focus, and face detection.
It supports video recording in 1080p at 30 fps. It has a secondary camera with VGA support. HTC Sensation XE runs on Android 2.3.4 Gingerbread upgradable to Android 4.0 Ice Cream Sandwich powered by Qualcomm MSM8260 Snapdragon chipset on dual-core 1.5 GHz Scorpion processor and Adreno 220 GPU. For internet browsing, it supports WAP 2.0/xHTML, HTML, and Adobe Flash.
It supports Java and GPS with A-GPS support. The battery is a removable Li-Ion 1730 mAh with standby time of up to 310 hours on 2G and 540 hours on 3G while talk time is up to 9 hours and 16 minutes on 2G and 7 hours and 20 minutes on 3G. It costs about EUR 140.
