taagred
10 points
Posted on - 10/23/2013
Hi People, Good Morning,
Connect 2 Laptops to one big LCD screen
I have a HP and IBM laptops and a 25 inch LCD monitor with HDMIÂ capability. How can i connect my both laptops into this 1 LCD so i can switch over both and work.
One could be doing some automated tasks while i work on the other
Thanks
You can connect two laptops to a single monitor, depending on the monitor specifications. A monitor with two HDMI ports, can have two computers connected to it. You can switch to any one of them at a time, using control (remote or other). In case of a Monitor/HDTV monitor (example Samsung P2770), you can have one computer connected to PC input and other to DVI.
You can also opt to use KVM (Keyboard, Video and Mouse) Switch to use a single keyboard to control multiple computers. Also check the synergy software. It also allows sharing your input devices between multiple computers/laptops. Â
