Hello expert, Urgently I need an information. I am using Samsung S2 mobile. I am looking to connect my Android mobile via cheetah sync USB to my PC because I need to transfer some photos, videos and music files. Please can you suggest me a proper way to connect without any error? Thank you.
Connect Android mobile via cheetah sync USB
Hey Dorothy, Hello there.
Cheetah Sync is like itunes for anDroid. Firstly you need to install on both the devices android and your PC, now connect them both then take up jobs you have to select the specific folders on both sides. These two folders are then kept in sync, though syncing isn't automatic you have to tap the sync button on your mobile app if you want to update your folder on PC or mobile.
Regards Ian M Tyner
Hello Dorothy, syncing your data between computer and android device or vice-versa with Cheetah Sync is so simple. All you to need to do is to set the mobile client and the desktop server of Cheetah Sync on their own platforms and see to it that they are synched with each other using a WiFi.
There are only two simple steps for you to follow:
First, you have to download the PC version of the Cheetah Synch utility and then install it on your computer. Take note, when using a Windows Vista or Windows 7 you must install the application with administrator privileges. No need to worry if you are a Windows XP user. You have to input the required details and the set-up will guide you through the whole process.
Second, if the installation process is complete the software will detect automatically the network and the IP address of the host computer then the next thing to do is to input the password and the default directory.
