Connect Host scan Signature Verification Error on Linux
Hi there,
On my Linux I have this error when I want to connect on my CISCO client account. Is for the first time when I have this error and I hoped that it will solve by itself, but it didn’t. Does anyone have a solution for my problem ?
Thank you !
Cisco AnyConnect Secure Mobility Client (unofficial)
Posture Assessment Failed: Hostcan Initialize error.
Answered By 0 points N/A #180072
The cause of the problem could be for different issues. You can try following steps :
1- Using cable through wireless
2- Uninstall and reinstall it.
Try to use standalone install package "anyconnect-macosx-i386-3.1.04072-k9.dmg".
After install the package  do not install the posture module then try to run it again and see if the problem solved.
