Connect HP scanner to wireless printer port
I have the HP printer or scanner and router which is wireless with printer port (USB). So I have connected the printer to this usb port. Is it possible to use printer's scanner in this way?
Yes, It is Possible for you to use the Printer's Scanner using Printer Port (USB) . Wireless and Printer Port (USB) is both a connector. It's only an Option.Your HP Printer/Scanner will work whether you use Wireless or the Printer Port (USB). HP Printer/Scanner is wireless-capable printer. Wireless means you can Print/Scan anywhere from your home without USB Cable.
Hello Trend,
You can use your scanner and printer without problem this way. Just hit Help button in your router's interface while you are at the printer port setup page to get the instructions or come back with your router's make and model for detailed instructions.
Thank you,
Tom
