Connect internet using Wifi modem
It's a very task to do.
Go to "Start" and click "Control Panel".
Now, click "Network and Internet" and click "Network and Sharing Center".
And then, select "Set up a new connection or network" and click "Set up a wireless Ad-hoc (Computer to Computer) Network" and click "Next".
Now, Name your network and if you want , then you can give a security key.
Now, you are ready to connect two or more PCs together.
Again, go to "Network and Sharing Center" and search for Network and connect all the PCs.
Now, you are ready to connect any no of PCs together through Wi-Fi.
Setting up a wireless network or a WiFi network on your home is very convenient for many people since this cuts off the cost if you are planning on connecting a couple of computers or terminals on your network. But before setting up your wireless network you must first learn how to setup a wireless router.
Evidently, any computer owner knows how important Internet security is and using a wireless router requires that same security. First, you should choose a hardware vendor or brand that you think is best for what you need. Next, you should perform a wireless survey before setting up your wireless router or access point. Checking the airwaves will help you find the best setting for your network. For the rest of the guide, please browse Setting Up Secure Wireless Networks in Homes
