Connect my nokia c6 to internet
Hi friend,
Of you are trying to connect internet in your phone then you can follow this process. To connect Nokia c6 with internet you have to configure two things on it. Go to settings option then connectivity>packet data> packet data connection and set it always online. And packet data setting option set by your network.
Other thing is go to configuration option from setting. Then default configuration setting>personal config. Here config two things item supported web and access point as your network. No need to give other information as home, user, password. Just maintain personal config as active mode. Then you can use internet in Nokia c6.
Well, it is pretty simple. To connect your nokia c6 to the internet you will need to have internet settings from the mobile service provider that you are subscribed to:
You may choose to access the internet using the phone browser, or download opera mini, which is a browser application mostly used by many mobile phones.
Regards
Thompson Locker
