To connect to my Windows Machine?
Apple products have always fascinated me. Recently I saw an Apple wireless keyboard. Since, I don't own a Mac, will it be able to connect to my Windows Machine? I can go ahead with my plans of purchasing only after this confirmation.
Best Answer by aditi7
Answered By 0 points N/A #114074
Hello everybody, I  can provide a suggestion to your problem and hope so it might help you..
Forward of all you impoverishment to corroborate if your organization (screen or laptop) has built-in Bluetooth installation. If yes, then you can arrange up your organization with the apple wireless keyboard. In fact with Vista and Windows 7 you can fitting unite and start working. For XP users you may make to set a compensated Bluetooth app to insert to your Apple keyboard. Formerly, you are in keep you can ask the staff there on these information. Let me see if you love boost questions.
Answered By 0 points N/A #114075
Yes you can since wireless keyboards are connected via blue tooth or with wireless receiver connected to USB ports. But this is not advisable to use because there are some keys that is not applicable to Windows functionality although Apple keys works with Windows key and when it comes to wireless connectivity, there were a little bit difference in speed. Wired devices are faster than wireless devices since the signal travels on air and there is some interference that might distract the signal.
Instead of purchasing apple wireless keyboard for your Windows desktop, why not to try some wireless keyboard comes from different manufacturers like Logitech. They have also the same looks and it is most suitable for windows desktop.
